carguy4sp's avatar
carguy4sp
Circuit breaker fuse panel coach
The rear of my interior coach lights are not working. Iam having trouble locating coach fuse panel on my 1987 Ford e350 Corsair class C RV. I have google searched with no luck.
Thanks
Rodney and Alicia
  • They should be somewhere inside. Have you looked in every space high or low or in the back of a drawer or bottom cupboard? Good luck
  • have to start looking in all the cupboards , normally with the 110v fuses, and the converter, sometimes under the rear bed.
  • If the converter is original equipment still, it probably hums more or less when it's plugged in. Maybe you can listen carefully for a 60Hz hum and see where it's coming from. Quite often (but certainly not always) the fuse panel and AC circuit breakers are at the same place, or very close by.
