RoyB wrote:
Both 50A legs inside the trailer power distribution center is being fed with a 30A source. You may not be using a standard RV30A-50A adapter. Not the two L1 - L2 legs must be shorted together
Roy Ken
IF both hot legs of 50A weren't jumper----half of AC panel would be dead, not just one position.
OP you need to remove that CB and test for voltage on the bus bar at that CB spot.
Bad line contacts/clips on CB OR improper installing CB would result in that CB not having voltage on load side.
One position on bus bar not having voltage is a head scratcher :H
Unless lugs are broken/bent on bar and CB will not engage
