LaPlaya
Aug 04, 2014Explorer
City water hookup and low pressure at the taps
I am hooked up to city water at the campground. I have a pressure regulator attached to the water tap, then my hose to the city water intake. There are no kinks in the hose. I am barely getting any water coming out of the taps, just more than a trickle... I removed my pressure regulator and there is a ton of pressure coming out the campground tap...I am not going to hook my hose directly without the regulator so I put back on my water pressure regulator and barely a trickle...I dont have any water filters so what is causing the loss of pressure. Before I go and buy a new pressure regulator, I want to be sure there isnt someething else I should check. Is there any chance that the water flows through the pump ? I know there is a little screen filter on the intake side of the pump, but I would not think the city water would circulate through the pump.. is there a screen filter somewhere else I need to be checking and cleaning ?
THanks.. Bill
THanks.. Bill
