RV_CONUS's avatar
RV_CONUS
Clas A Drivers license requirement State of Nevada
What is the accurate interpretation of this licensing classification for a Class A RV under 26,001 lbs.
This is the Nevada code. Clear as Muddddd! Anyone speak legalese?
What class license is required if the Motorhome is under 26,001?
NAC?483.110??Drivers’ licenses: Classifications; miscellaneous restrictions and endorsements. (NRS 481.051, 482A.100, 483.220, 483.235, 483.908)
1.??The holder of a Class A noncommercial driver’s license may drive:
(a)?Any combination of vehicles with:
(1)?A gross combination weight rating of 26,001 pounds or more, which includes one or more towed vehicles with:
(I)?A gross vehicle weight rating of more than 10,000 pounds; or
(II)?A gross vehicle weight of more than 10,000 pounds; or
(2)?A gross combination weight of 26,001 pounds or more, which includes one or more towed vehicles with:
(b)?Any combination of vehicles not exceeding 70 feet in length with a gross combination weight rating of 26,000 pounds or less so long as the gross combination weight rating of the towed vehicles does not exceed the gross vehicle weight rating of the towing vehicle; or
(c)?A vehicle falling within Class B or Class C, but may not drive a motorcycle or an autonomous vehicle in autonomous mode unless the holder obtains an appropriate endorsement.
2.??The holder of a Class B noncommercial driver’s license may drive any single vehicle with a gross vehicle weight rating or gross vehicle weight, whichever is greater, of 26,001 pounds or more, or any such vehicle which is towing another vehicle which does not have a gross vehicle weight rating of more than 10,000 pounds, and all vehicles falling within Class C, but may not drive a motorcycle or an autonomous vehicle in autonomous mode unless the holder obtains an appropriate endorsement.
3.??The holder of a Class C noncommercial driver’s license may drive any single vehicle, or combination of vehicles, that does not meet the definition of a vehicle for which a Class A or Class B driver’s license is required, including, without limitation, a moped or a low-speed vehicle, but the holder of a Class C driver’s license may not:
(a)?Drive a motorcycle, unless the holder obtains an appropriate endorsement;
(b)?Tow a vehicle or a combination of vehicles with a gross vehicle weight rating or gross combination weight rating, as appropriate, of more than 10,000 pounds, unless the holder obtains a J endorsement;
(c)?Drive a combination of vehicles exceeding 70 feet in length; or
(d)?Drive an autonomous vehicle in autonomous mode unless the holder obtains a G endorsement.
NAC 483
1.Class A Motorhome 26,000 = Class C?
2.Class A Motorhome 26,000 towing 2500 lb auto = C or B?
Or ??
