โSep-21-2015 03:53 PM
โSep-23-2015 07:52 PM
โSep-23-2015 04:28 PM
โSep-22-2015 07:46 PM
โSep-22-2015 03:52 PM
Koop wrote:RFCN2 wrote:
I believe Entegra still puts a custom chassis under some of their models. And I think Tiffin puts the Peak chassis under a few of their coaches which is a custom chassis.
The Peak chassis was designed by Gary Jones and made by Western RV exclusively for Alpine Coach. Tiffin has their own chassis available - it's called a Powerglide and shares some of the Peak features.
โSep-22-2015 02:51 PM
โSep-22-2015 02:48 PM
โSep-22-2015 01:13 PM
โSep-22-2015 12:30 PM
โSep-22-2015 09:10 AM
Mr.Mark wrote:
RichardClark, this is somewhat off topic but if you pull a trailer, I would want the tow vehicle inside the trailer to have the capability to pull it.
Your new coach will have to go in for service at some point. The trailer will have to be stored somewhere while service and repairs are made.
Although we are not full-timers, you just can't beat traveling by RV!
MM.
โSep-22-2015 09:05 AM
holstein13 wrote:
The Entegra Anthem is not in the same league as the Newmar King Aire.
If you want an apples to apples comparison, you have to look at the Entegra "Cornerstone" and compare it to the King Aire.
The Anthem has a Spartan Mountain Master chassis while the Cornerstone and King Aire have the Spartan K3 Chassis. There is a huge difference between the two. 600 HP ISX vs. 450 HP, 200 gallon fuel tank vs. 150, Passive steer tag (newmar only) vs fixed, Allison 4000 transmission vs 3000, Air leveling vs not. and on and on.
Take a look at this: ***Link Removed***
If you have any questions about the King Aire or the K3 chassis, that's my area of expertise.
โSep-22-2015 07:03 AM
โSep-22-2015 05:46 AM
richardclark wrote:The Entegra Anthem is not in the same league as the Newmar King Aire.
The underlying theme amongst all the responses is to look more closely at Newmar. I've went to their site and it appears the King Aire is the line that I should consider in equivalence to the Entegra.
โSep-22-2015 04:44 AM
โSep-22-2015 03:11 AM
