โJun-17-2014 04:38 PM
โJul-03-2014 11:55 PM
โJul-03-2014 08:32 PM
โJul-03-2014 08:10 PM
โJul-03-2014 08:08 PM
โJul-03-2014 11:21 AM
โJul-02-2014 03:32 PM
โJun-29-2014 10:31 AM
โJun-22-2014 09:00 PM
โJun-22-2014 08:45 PM
timmac wrote:
What year of Wrangler is that without steering lock, the reason I ask is my 04 Wrangler has steering lock, maybe the OPer is not looking for a new Wrangler if the new ones no longer lock.
โJun-22-2014 07:18 PM
BobGed wrote:
If you're looking at new vehicles I would like to recommend the 2014/15 Jeep Cherokee. I previously towed a 2011 Wrangler and didn't think anything could be any simpler to tow, but the Cherokee is.
Foot on brake pedal, put the ignition in the On/Run position, but do not start the engine. Shift trans into Neutral. Using a ball point pen or similar object, press and hold the recessed Neutral button until it stops blinking. Shift the transmission into Park, turn the engine Off, exit the vehicle and lock the doors.
No fuses to pull since there's no drain on the battery, and you can tow it as fast as you want as there are no manufacturer maximum limits.
I would suspect the Grand Cherokee procedures are the same, but that puts you out of the category of Wrangler and Honda CRV.
โJun-22-2014 07:15 PM
โJun-22-2014 05:28 PM
โJun-20-2014 08:17 AM
โJun-20-2014 05:35 AM
