dons2346 wrote:
Another advantage is when you are in a tight campground and there isn't a pull thru. Spent 20 minutes the other day watching a guy try to park a 5th wheel with his big truck. Spot was a simple one for a MH
How exactly do you back up with the toad attached? Assuming you learn how to back up, the 5th wheel has the advantage.
Also, if you goal is push button ease, you can get generators and auto leveling on a 5th wheel. The only horror, is the 10-15 seconds it takes to walk back in the rain from the truck to the trailer. With the price difference of motorhomes, that's a pretty hefty price to pay for the couple times per year when you might get your hair wet.
We find without rushing, we set up or tear down as quickly as most motorhomes do. It's cheaper and easier to maintain a single drivetrain.
The fuel savings with a toad is largely a myth. With MH's typically getting worse MPG by a significant margin compared to PU's towing, you have to put a lot of miles on the toad to make up the difference. The thing is we usally camp close to what we want to see so we aren't putting a ton of miles on the truck. (You may have a specific usage that differs but for most, I believe you will find the same issue if you run the numbers)
If we were to consider a MH it would be because we have need of a particular TOAD. Say you are into off roading and really want a jeep. That's tough with a 5th wheel unless you want to double tow or the spouse drives seperately. In that case a MH makes a logical choice.
