Dakzuki wrote:
"The Best of Both Worlds.". Actually a compromise between both worlds.
'zacly what I've always thought. The Walmart "Marine Start" batteries in our boat, and the Walmart "Deep Cycle Trolling Motor" battery in our coach "house" only carry a one-year warranty, but they actually last more like three years or so. About what warranty would be if I tried to use car batteries instead.
"Dual" is more like "Neither." If you don't have the room for two, just get the biggest true Deep Cycle that'll fit your House Battery compartment.
In many cases, you CAN expand the compartment. As I noted above, depends on how you use the RV. For example,
![](https://farm2.staticflickr.com/1477/24361285669_36540b29e0_n.jpg)
width=320[/img]This is our Jayco. The "compartment" is more like a "hole." It has no front, no bottom, extends back to the Chassis, and its only rear is the front of the next compartment. Another Jayco owner modified the area to accept a two-battery tray, and ordered a bigger door for the enlarged cutout he made in coach body. Still another converted the area behind the battery (white plate is CATV Jack) where the shore tie cable stores. Basically left one battery where it is, installed another in the re-purposed compartment. All I did, was convert our permanently mounted battery tray to a pull-out. Used heavy duty drawer slides from Home Depot. I'm happy with the result. Can check water now. Also, project justified buying an angle drill!
