CA_Traveler
Nov 13, 2021Explorer III
With a voltmeter connected to frame ground (not a wire) check for 12V at a bulb and if so it's getting power. Then unless the bulb is bad there will be 12V on the ground side. Use this method to isolate the problem area and corrosion/loose connection are likely suspects. Or a critter had a tasty wire lunch. :B
Intermittens can be difficult to find. Yours is relative easy - turn on the lights and start isolating.
38,705 PostsLatest Activity: Jan 24, 2025
