Tom_Barb's avatar
Tom_Barb
Continued dirty fuel problems.
As many readers here know, we have been having dirty fuel problems. We bought our Newmar in 2009, it had sat 9 years in dry storage I had only 8700 miles on it. We worked our way thru. the wake up period with new hoses belts, and tires, and were really happy with the coach. 2010 we were returning from a trip to NY, and the coach started to loose power, and would quit, we would wait 15-20 minutes and it would start and run but at a lower speed than normal. I changed fuel filters and it returned to normal, I changed filters 2 more times from N.M. to Wa. all were contaminated with a black debris looking like soot from a chimney. It's a had particulate matter and fells like black sand.
I was totally convinced that we had loaded a bad / dirty fuel.
Once at home, I drained all fuel, removed the fuel tank, hoses, filters, and associated units flushed and cleaned them, replaced all the equipment. and it has run great until this month. we now have 41k on the cummins. we find the whole fuel system is contaminated again.
Same stuff, same symptoms, and same Fault codes of low fuel pressure.
I have now replaced both fuel filters, re-set the fault codes and the coach runs great again.
But where in the world is this stuff coming from?
I believe the Cummins 8.3 ISC 350 horse is producing the carbon, and returning it to the tank, which is clogging the filters. I have asked Cummins for assistance but have not heard from them yet.
