Convection Microwave
Rwake901
We have a Convection Microwave in our motorhome. We have never used the convection oven part of it. For those of you that have do you leave the turn table in the oven when using it or take it out? Thanks
20 REPLIES 20
naturist
I leave the turntable in. Do note the warmup time (YMMV) and either take the time to pre-heat when the cooking instructions call for it, or add time to the specified baking time to account for it.
I frequently do frozen biscuits and have found that the official 20 minutes, which is perfect for a pre-heated oven, requires 24 minutes if I don't pre-heat. The turntable does insure even cooking/browning, which if you think about it, would be a problem, since having all the heat coming from one side could be expected to cook unevenly.
imgoin4it
My DW uses the convection oven in the coach for everything. Liked it so much we put one in the house and she uses it far more than the stove oven. And leaves the turntable in
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
DrewE
lap527 wrote:
I think I read somewhere if using the convection part the rack is supposed to stay in. I baked some cookies in ours and surprisingly they were pretty good. Lol.. it was weird to leave metal in there though. Our friend baked biscuits in his.
The convection part doesn't energize the microwave part. It's basically just a toaster oven with a fan to circulate the heated air around.
lap527
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
MountainAir05
Ours stays in, We also have a rack above that is used.
10forty2
I leave the turntable in place....not sure if I'm supposed to. But, I've cooked several baked potatoes at 475 degrees for an hour at a time and so far no problems. Cooked a couple of breakfast casseroles in it as well...also left turntable in place. We don't do a lot of cooking inside the rig, and usually limit it to the above. Definitely o frying or anything that will lead to grease and heavy odors.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
