Its the nature of the beast and we ALL deal with the same problem. You get used to it and it will become second nature to you not to put plug in 2 items on at the same time. Same will happen if your DW uses a dryer, toaster etc. And appliance especially the ac draw more when they come on.
snip it:
http://rvservices.koa.com/rvinformation/rvmaintenance/rv-converters-and-amp-draw.aspIt’s important to note that in an RV you can’t run several appliances at once or you’ll blow your breaker. Here’s the skinny. Your RV has either 30 amp or 50 amp capability. Amperage is the amount of power available to use. Each appliance pulls a specific number of amps. Exceed 30 or 50 amps (depending on your rig’s system) and poof – the power overloads and the breaker trips. Here’s a handy list of some of the typical appliances and the approximate amps required to operate them:
120 Volt AC Amp Ratings
Appliance or Electronic Equipment Estimated Amps
Air Conditioner (X number of A/C) 12-16 Amps
Blender 5-6 Amps
Coffee Maker 5-8 Amps
Compact Disc Player 1 Amp
Computer (Laptop) 2-3 Amps
Converter 1-8 Amps
Crock Pot 1-2 Amps
Curling Iron <1 Amp
Drill 2-6 Amps
Electric Blanket 0.5-1.5 Amps
Electric Fan 1 Amp
Electric Water Heater 9-13 Amps
Electric Skillet 6-12 Amps
Hair Dryer 5-12 Amps
Iron 5-10 Amps
Light (60 watt % 120V) <1 Amp
Microwave 8-13 Amps
Microwave (Convection Oven) 13 Amps
Refrigerator in AC mode 5-8 Amps
Space Heater 8-13 Amps
Television 1.5-4 Amps
Toaster 7-10 Amps
Vacuum (handheld) 2-6 Amps
VCR 1-2 Amps
Washer/Dryer 14-16Amps
