There are a lot of posibilities.
First the CC uses vacuum so if you have a vacuum leak in the right place. NO CC.
I had a bent pin on a connection.
Blown fuse (it uses 12 volt as well) other bad connection
Bad brake light switch. Have someone stand behind the RV and see if the brake lights are on full time.
Also blown brake light fuse/burned out bulbs. Have partner make sure they come on when you push the pedal
NOTE that last is my #1 suspect.
On edit. a bad GROUND on the brake lights will do it too. But not consistantly(IE when headlights on no CC.. lights off it works).
