SGKane
Dec 09, 2015Explorer
Cummings Diesel
We are looking at a "new to us" Itasca Horizon 40'. we have two to look at. Both have the same floor plan however one has the 400 hp the other has a 350. This would be our first diesel motorhome, is ...
Ivylog wrote:
The ISC 8.3L 350 HP/1050 torque is a good engine and the ISL 8.8L 400 HP/1200 torque engine is nothing but a stroked ISC and it's an even better engine. It would help if you posted what year as it's possible to have a ISB 6.7L 350 HP/860 torque engine but doubt they would go two steps down from the ISL 400. The 1 HP/100 lbs is a pretty good rule of thumb so if loaded weight plus toad is 35,000 lbs... 350 is enough, but 400 would be better and if you can control your right foot, get as good or better MPG.
Because the Allison 3000 tranny is only rated for 1200 ft lbs torque, the ISL 400 has a flat torque curve from around 900 to 1400 RPMs giving it good pulling power over a broad band. The ISL 400 should have a torque rating of 1300 but because of the 3000 tranny it's only rated 1200. At 400 HP it's at the upper limits of it's rating... like in a ambulance.
