mhbell
Oct 13, 2015Explorer
Dash AC intermittently blowing cold air, then hot
My Dash AC blows cold air when the engine is cold, but after it gets warmed up it blows hot air. I assume that it has a Evans Tempcon Electronic Coolant Valve that can shut off the coolant to the heater core when the dash AC is turned on. There is also a Vacuum Pot on the bottom of the AC shroud which I think operates a flapper blending door between the heater core and the AC. With the engine cold and idling, I get cold air. But going down a flat highway engine not under load I get hot air. Pulled into a rest area and with engine warm, and at idle I still get hot air. Is it the Evans Coolant Valve that is bad, or something in the controls. I have heard that some replaced the valve with a manually operated ball valve to use during the summer months. Can anyone shed some light on this and is there a way to check it out.
Mel
Mel
