- Jarvis1ExplorerJust got the problem fixed
Was leaking at the connection to the condensor - mikestockExplorerYou haven't said if it just quit cooling or totally quit blowing air.
Mine totally stopped blowing and upon checking the electrical panel I found a contact that attaches to the fuse panel was failing to make good connection. Cleaned up and had no more trouble. I'm seldom this lucky. - aintnothinExplorerCheck your ac condenser fan. My ac quit working and found that the fan had froze up
- GrooverExplorer II
prstlk wrote:
We used deluxe rv repair, mobile service, very knowledgeable. If he can't help he can point you 928 342 1230 his name is Larry.
Have you thought of trying a freon refill kit? Available everywhere and most have a leak stop additive. It's an easy fix for minor leaks. Easy to use takes minutes, cost about $50.00
Let us know
Ditto on that. Mine even has an old fashioned sight glass that makes knowing how much to put in easy. Just fill until the bubbles go away. With all of the plumbing required to go from the dash unit in the very front all the way back to the compressor in the back I expect this to be a recurring problem so I am just going to carry the refill kit from now on. - prstlkExplorerWe used deluxe rv repair, mobile service, very knowledgeable. If he can't help he can point you 928 342 1230 his name is Larry.
Let us know - bobcatcharlieExplorerCheck and make sure the valve is shutting off hot water.
- JNW57ExplorerJust had mine fixed by Frank's Mobile Repair (928) 341-5137. $75 service call & minimum 1 hour @ $75.
About Motorhome Group
38,705 PostsLatest Activity: Jan 20, 2025
