PARDRIVE1's avatar
PARDRIVE1
dead 2015 axis 24.1 chassis
I changed the chassis battery and now have absolutely NO power to cab. No ignition, no dash lights when key turned...nothing. I'm a plumber not an electrician, and brand new to RV. Gotta be a simple fix, but I can't find it. HELP>
  • Did you forget to throw the battery disconnect switch after you changed the batteries?
  • oldave wrote:
    It would help to know what rv you have .
    Usually when this happens something has been wired up wrong or
    a wire has been left off .
    Look around the battery compartment to see if a wire has fallen
    down out of sight .
    This may be a small wire , not necessarily a cable .
    Did you take a picture or draw one ? Always take a picture several
    pictures are even better . Memory will not always work .
    The title for the post says it's an AXIS 24.1.
    To the OP - if you replaced the battery and nothing works, my guess is you didn't hook something up correctly. Hopefully you didn't hook the battery up backwards. Did you miss a ground?
  • It would help to know what rv you have .
    down out of sight .
  • Is it possible that you hooked up the battery backwards.
    Jerry Parr
