Poppy2003
May 06, 2021Explorer
Dead batteries
winter stored RV for 6 months, no shore power, now batteries are dead, can I jump start with my car battery?, my Generator also not starting, thank you.
navigator2346 wrote:
Yes to the jump start. After you get the coach running, you might be able to start the generator after a few minutes. It would be best to get a stand alone battery charger and make an attempt to charge the batteries instead of trying to use te generator and on board charger. Your batteries could be toast
garym114 wrote:
probably not, use a 110v battery charger. This may not work because the batteries sat a long time with no charge, totally dead, may have to be replaced.
Next time move the negative cable from all batteries.
see my signature
jdc1 wrote:
If it's a diesel, you'll need more than a car to jump start it.
