Sep-23-2016 10:41 AM
Sep-27-2016 02:15 PM
Sep-27-2016 01:53 PM
I agree that the emission requirements cause the engineer's to scramble but we would be in a mess if we didn't have pollution controls. As I've mentioned in the past, Los Angeles has such thick smog before catalytic converters that you could almost cut it with a knife.
You couldn't even see the houses just off of the freeway it was so bad. It's probably 90% better.
After seeing what the 'lack of' pollution controls looks like in India, I like where are are today, the pollution was awful there.
Sep-27-2016 01:47 PM
Sep-26-2016 11:49 AM
Sep-26-2016 10:17 AM
Ivylog wrote:
NOx is EPAs current attempt to justify it's existence... actually expansion. Guess they do not know they cannot stop lightning. CAT did not procrastinate itself out of the Diesel engine business... trying to meet the ever increasing 2010 requirements did.
Sep-26-2016 09:02 AM
Sep-26-2016 08:26 AM
mpierce wrote:Mile High wrote:
Oh I think most of that is hoopla complaining from the peanut gallery. If there weren't federal mandates, there probably wouldn't be any effort to clean up emissions by the manufacturers because there is no profit or glitter associated with it. We would still have crankcase blow down tubes dropping oil on the ground.
If you ever want to remember what it used to be like, watch an old 60s movie and see the smoke coming out of the tailpipe as well as the drivers nostrils. I would never wish us to go back to that. I have a 1952 Cushman Eagle at home the puts out more pollution through that 1 cylinder aspirated engine than my Cummins, and that was normal.
Maybe "hoopla" to you, but I know, by personal experience, of a number of independant truckers that went broke because their new trucks spent so much time in the shop, working on the emissions systems.
Cleaner air is fine. It is good. But, the EPA forces the changes so fast, that technology cannot keep up, and the mfg's do not have enough time to work the kinks out. So, the poor buyers have to do it, in the shop.
Sep-25-2016 06:54 PM
Sep-25-2016 12:54 PM
Sep-24-2016 02:17 PM
mpierce wrote:
az99:
So true! The company I drive for, over the road, has had MANY newer trucks into the shop, for days at a time, trying to trace down emissions/DEF problems! Waaay more than normal engines. Eventually, they will get the problems sorted out, but by then, NEW controls will be called for, and the problems will start all over again!
Sep-24-2016 01:58 PM
Sep-24-2016 01:13 PM
Sep-24-2016 12:41 PM
Sep-24-2016 10:36 AM
JumboJet wrote:Bret's statement is exactly accurate. When the pre-DEF engines were tuned for maximum power and economy it drove the EPA guys nuts because the products of combustion were causing pollution which could be tuned out on these same engines. The down side of that was that when they were tuned for better emissions, power went down and they actually got poorer mileage. Many who had a Cummins engine that was made in the 1-3 year period before DEF came in came in will probably remember the recalls issued to re-flash the ECM that were common. Each time it happened mileage dropped. In fact, if you had your rig in the shop that was engine certified, you got the re-flash without them telling you they did it or even consulting you. I spent a lot of time on the phone with Cummins and with service people about this. When the DEF engines first came out one of their selling points was better mileage and more power. This didn't have anything to do with the DEF (as many have said, DEF is only used in the exhaust stream after the exhaust leaves the engine) but what it did was enable engine makers to again design and tune for power and economy without the EPA clowns beating them about the head and shoulders. Was this better or worse? You decide how much pollution an RV contributes to the world smog when most are driving 3000 - 5000 miles a year and how much the extra equipment weight, complexity and maintenance are worth to you.wolfe10 wrote:JumboJet wrote:
DEF is introduced in the exhaust stream and has no effect on engine power.
While the statement is true, it may be a little misleading.
Because of DEF, the engines can be tuned for more power and better economy.
Very similar to what happened to gasoline vehicles between 1974 and 1975 when catalyst converters were added.
I was referring to the post title "DEF diesel engine". The engines are designed for leaner burn but produce a nasty exhaust that the fluid converts to water and nitrogen via the SCR.
Are the newer engines that require DEF actually providing better economy or just tuned for more HP?
