Most RV sides are put into place by adhesive. Normally it is a Styrofoam wall between the studs.
Crane Composite is the largest supplier of material for siding. They have one product which is luann wood backing over composite Filon material. If water gets behind the wood will rot sooner or later.
They have a repair process, which involves either cutting out the whole section or grinding out the area if it is the size of a quarter.
I would go to that site and search under the support side.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
