ragdogs wrote:
I took a look under the Moho. My levers etc are under my mattress in corner of Moho It drains/leaks when I turn the water pump on and it is coming out underneath. I am unable to attach the pic but it is two tubes/hoses directly under my bed area that drains the water tank when I put the pump on. I realize it is a valve or plug but I just can’t find it or figure it out.
There might be a petcock (valve) that you can turn on/off next to the water pump.
The ends of the tubes:
If one has an open end and one has a capped end that can unscrewed, then the open end tube should have a valve somewhere above that tube. If your water pump is near that location, that would my guess for its location.
You would just to remove the cap off the capped tube to drain that one. That's usually the hot water drain. The other open ended tube is the cold line and it can sometimes also be the low point drain for your freshwater tank. If your system is designed that way , that line will take longer to drain than the capped line because of the volume of water being drained out of your water tank.
