kmsavage1
May 02, 2014Explorer
Diamond Shield
How do I get diamond shield off of my Class A. It has gotten mildew under it and I need to get it removed to clean up the mildew.
katysdad wrote:
Diamond Shield tech used a wallpaper steamer to heat and soften the film then cleaned up behind it with zylene(xylol). The steam will not over heat the film or blister the paint, but soften the glue behind it without making the film too weak to pull off in larger pieces. I believe he also used the plastic razor blades to remove the film without damaging the paint.
