EMD360 wrote:
Recommended differential service is between 50,000 and 60,000 miles. So it was time. They just replaced the gasket and the fluid. Because it was just service the warranty does not cover it. Didn’t hurt to ask. I still don’t have the RV though because they were not happy with the alignment so sending it back for a rear axle alignment. These look like they are relatively uncommon. But if the steering wheel is off center or there is pull one way or the other I guess it’s possible the rear axle can be adjusted. Can’t find much on it on Google. So the shop that does alignment for them can’t get to it until next week. It’s drivable they say but I didn’t want to experience a problem after all the work I’ve had done so I won’t get it until 2022!
Fwiw, unless there are some extenuating circumstances not mentioned, it is virtually impossible to knock the rear axle of a solid axle vehicle out of “alignment” and it is 1000% not adjustable. If for some reason there is a gross misalignment or bent axle, it is a mechanic shop or body shop job.
Or in other words, you’re likely being sold a bill of goods on the rear alignment. Beware.
