dvleemin
Aug 27, 2020Explorer
Dimension Inverter/Charger not charging batteries
Hi,
I was hoping someone had some ideas on how to resolve an issue I have with my Dimension Inverter/Charger not charging batteries.
Here are the details on the unit:
- 2005 Itasca Horizon 40AD
- Dimension 12x20B3RT Inverter/Charger
Problem:
- when plugged into shore power the batteries are not being charged.
- on the control panel it says: "CHGR-OFF NO INPT" AND "INVERTER-OFF
- the house and coach battery voltage is around 12.7 and shows that it is not charging
- The control unit does show that its on 30 amp
- 120V is available throughout the unit
- running the generator and not connected to short power results in the exact same result
- all fuses on the Dimension, on the chassis, and on the house seem fine
I was able to find the manual for the Dimension but not a lot of help: https://www.rvtechlibrary.com/electrical/dimensions_owners.pdf
I'm guessing some sort of transfer switch type of issue?
Anyone have any ideas on next steps to trouble shoot it?
Thanks,
Darryl
Problem:
Thanks,
Darryl
