Snomas
May 18, 2013Explorer
Disappointed in Cummins Engine
I am very disappointed in Cummins Engines. I took my Dutch Star in for an exhaust manifold leak and then the problems started. After removing the exhaust manifold, bolts broke off in the head,they found the head would not pressure test to specs, results new head was required and manifold, the turbo charger had to be replaced, the fuel pump leaked when it they went to finish and start it and resulting in having to replace w/ new fuel pump and new fuel lines. So I got a new exhaust manifold, new Head, new Turbo Charger, new fuel pump and lines. the parts alone cost over $7500. plus tax & labor to install. I have 84000 on the MH. You would think a cummins engine and related components would last longer than 84K miles and 11 years. I'm just venting!!!!
