Snomas
Oct 07, 2021Explorer
Does it matter?
Does it matter if I get my 2006 Winnebago 29H alignment before I put on sway bars or should I wait? I get a little wander above 50 mph. I do have a steering arm already installed!
Snomas wrote:wolfe10 wrote:DougE wrote:
Sway bar doesn't impact alignment and may help sway issue slightly. Guess you replaced idler arm (steering arm?) due to wear? Have your alignment shop set the caster close to the maximum spec.
All good advice.
I thought It was the camber +5 degrees that would heal the wander problem?
