DKLilly67 wrote:
This morning we got plain outlets ( just trying to close circuit and go from there) my husband very carefully hooked them up ground to ground, white to gold, black to silver. We can now read power to the outlet but nothing to the outlet works .
I hope you have a typo there. It should be ground to ground (usually a green screw), black to gold screw, and white to silver screw. The black is the hot line, the white is the neutral line. If wired the way you described, things connected to the outlet should work, but they are a shock hazard. Outlets have a "load" and a "line" side. The "line" side received the black, white & ground wires from the breaker panel. The "load" side is used to feed the power and protect the other outlets downstream. The fact that they don't works suggests that either they are wired incorrectly (more so than you mentioned) or that the breaker which feeds the those outlet(s) is tripped.
ON EDIT: Reading your next reply, I see that you figured out the hot & neutral reversal. That's a step in the right direction. I might also suggest, if you don't have one already, that you purchase a GFCI receptacle tester similar to
this one. There are many variations, all do about the same thing, and any hardware store should have them. Personally, I recommend the ones with the GFCI test button. Oh, and the yellow sticker is there mostly to indicate the "load" terminals on the GFCI. Where it's placed has no bearing on the circuit operation. I have no idea what "hopelessly locked up" means. If they were tripped, hitting the "Reset" button should fix it.
And you really should reinstall the GFCI outlets. Without them, you have a serious shock hazard. I don't really think the GFCI outlets had anything to do with your original issues.
I don't like to say this, but it sounds like the people you have working on the electrical issues don't really understand what they are doing. Understand that electricity can be lethal and it's important to have a good understanding and respect for it.
You might want to consider hiring someone who is skilled in electrical work to straighten this out.
Good Luck,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
