JaxDad
Mar 07, 2023Explorer III
wa8yxm wrote:
Laws vary from state to state. Some states reaquire special endorsements for any vechicle that has air brakes.. Or any vehicle that's over xxxxx pounds or so many feet long or or or or or or
Some don't.
However one thing that is common to all states.. If your license allows you to drive it in your home state... You are good in whatever state. And a good part of Canada as well (not sure about all of Canada)
So you are going to have to research your state.
That is sound advice, reciprocity covers your drivers license, but not endorsements or other required permission.
In numerous jurisdictions (including here in Ontario) the equipment regulations require that an air brake system be inspected (visual and function) on every day the vehicle is in motion by a ‘certified technician’, the air brake endorsement is that certification.
While it’s rarely enforced, usually only in spot checks or following an incident, it’s a potentially expensive lesson if you don’t have it.
Another misunderstood point with ‘equipment regulations’ that comes up with DP’s is overall length. If you pull a trailer and live in a State where 65’ is the legal maximum, say in Florida, you might have a problem when you cross into Georgia where it’s only 60’ maximum.
38,705 PostsLatest Activity: Jan 22, 2025
