Campincarters's avatar
Aug 21, 2015
Dropping gast tank to check vent line
I bought my pre-owned rv in may. I really like the unit but have had a difficult time filling the gas tank. So my mechanic is going to probably drop the gas tank to see if the vent line is clogged. Has anyone else had to have this done. 2008 Chevy Chassis
  • I had a smog issue due to a leak in the top vent line. I absolutely did not want to deal with dropping that tank at home. I gladly paid to have that done.
    Jose
  • j-d's avatar
    j-d
    Your mechanic experienced pretty much what I did working on the Jayco. The lines were drooping, they were deteriorated, and it was BARELY possible to reach the tank without dropping. And yes, it fills more easily than it used to. I try to park nose-down at the pumps if I can, but level works. I doubt if I could fill it nose-up.
  • Had the rv looked at by my mechanic. What he found was that the fuel line did have a sharp turn in it that could possibly be a kink. Also the rubber hose line was cracked. Not all the way through but was going to be an issue soon. He did not have to drop the tank as he was able to get to the line. He did say that he found some gas in the vent line and that the fuel line itself got thinner as it got to the tank. He blew out the line and did remove some gunk. He thinks the biggest issue was that the hose had a few dips in it which would cause it to back up. When he replaced the hose he tried his best to keep it level or angled toward the tank. I won't know the result till I fill in another state. In CT we have vapor nozzles which I from what I am told restrict air flow. Here's hopping.
  • I had a 1 ton drw Chevy that I had a service body installed. The first few tanks of fuel were hard the put in. I brought it back to the service body installer. They found the rubber filler hose kinked. Just a thought. Good luck, hope it's an easy fix
