- RacklefratzExplorer II
dcmac214 wrote:
NO! Not WD-40! 1st it's not a lubricant. More important, it'll dry and turn sticky in the process, collecting dust, dirt and whatever, leaving you with a mess to clean off. My go-to is dry silicone spray.
You're right about WD-40, which is always among the recommendations each time this subject comes up. The "WD" in WD-40 stands for "water displacement"; it was never intended as a lubricant, although it's widely MIS-used for that.
Not to hi-jack the OP's thread, but our coach has HWH hydraulic jacks installed from the factory, and HWH's position on lubricating their jacks is "DON'T". Just keep 'em clean. Any build-up of any kind of lubricant on the moving parts of the jacks is a dirt-magnet, and the grit on the jacks can destroy the seals over time. HWH says if jacks need repeated lubrication to get them to retract, there's likely to be a problem somewhere - weak retraction springs, etc. - gb76087ExplorerMy brake is bad on left rear jack. I did a google search on 3010001428(brake kit) and didn't get any hits. Anybody know of a source for a replacement?
- ernie1ExplorerDry silicone is what BigFoot Levelers recommends. I spray the jacks with the silicone and wipe them clean and respray again with a light film and leave it like that.
- Bruce_BrownModeratorI think most of you guys are talking about hydraulic jacks. The OP was asking about electric jacks. Big difference.
- dcmac214Explorer
C20 wrote:
Wipe them down with Windex and the spray them with WD40 about once a year and they will work perfect
NO! Not WD-40! 1st it's not a lubricant. More important, it'll dry and turn sticky in the process, collecting dust, dirt and whatever, leaving you with a mess to clean off. My go-to is dry silicone spray. - C20ExplorerWipe them down with Windex and the spray them with WD40 about once a year and they will work perfect
- joelcExplorer IIIIf you have cylinder like pistons use silicone spray.
- tinkererExplorerI have electric jacks on my 2007 Discovery and they were nothing but trouble.The problem was the brakes we getting corroded on the jacks. Power gear had a updated seal kit which I installed. After installing the seal kit and cycling the jack every 30 days I have zero problems.
- Bruce_BrownModeratorBased on the year I assume they're Atwood Level Legs? If so, there really isn't much you can do without disassembling them. The gearsets are grease lubed, as is the screw part, to some degree.
About Motorhome Group
38,707 PostsLatest Activity: Feb 17, 2025
