Lawdawg21 wrote:
Hi all. I have a new to me 2013 sportscoach cross country dp. The drivers side of the coach has a short that only happens when I turn a tv on that is on that side. All outlet's cut out then back on. It does it repeatedly with no rhyme or rhythm. The passenger side or ac's don't do this. Any ideas?????
Well, we know it's not a short, anyway.
I'd probably turn every breaker off, except the affected circuit, then plug in a few small lamps down range from the breaker box and see which ones blink off and on if this be the case. This should allow you to pretty much isolate it to a given outlet.
