โJan-21-2017 06:15 PM
โJan-23-2017 01:22 PM
โJan-22-2017 08:21 AM
dougrainer wrote:
What I do is this. You need a large gauge wire from the Dash control to the rear to transmit a GOOD positive 12 volt signal to the rear brakes. I run a 12 gauge dual sheathed wire from the front to the rear. One wire is connected to the rear tow plug(for the electric brakes). The other wire is connected to one of the rear brake light wires that is HOT when brakes applied. This kills 2 birds with one stone. The newer models that have a so called prewire, the Gauge of the wiring is NOT adequate for electric brakes usually that wire is 16 gauge, way too small for a 40 foot run. You can also tap off the Air brake solenoid at the front that activates the Rear Brake switch. But, since I am running a Control wire already, I would rather connect to the rear brake light harness. Doug
โJan-22-2017 05:53 AM
โJan-21-2017 06:19 PM
jwolf55 wrote:
I need to put an electric trailer brake controller on my 2000 Tradewinds, with a Freightliner chassis and a turbo cat.
Where is good place to get a brake light signal?
I guess it is not prewired as I could find anything.
