Mr_Mark1
Aug 30, 2016Explorer
Frankie,
As mentioned, I would definitely have the radiator set-up cleaned. You can do this yourself with Simple Green and a water hose (do not use super high pressure that will bend the fins).
Spray the Simple Green (several versions made, pick the best for your application) generously and let it sit. You can repeat this several times. If there is any way that you can hook up to hot water that would be a plus.
Your coach is almost 12 yrs. old, your radiator could be pretty dirty if it has never been cleaned.
Good luck,
MM.
Good luck,
MM.
38,705 PostsLatest Activity: Jan 14, 2025
