jolooote's avatar
jolooote
Entrance Door Strut mount torn out. 2020 JayCo GrayHawk
The Entrance door Strut (Shock absorber) ball mount on the bottom of the door has torn or snapped out of the door aluminium. Has anyone had this problem? How to fix? It looks like the ball mount was some kind of Rivet machine mounted into the door metal. Can't re-rivet a mount into it. Looks like I'll have to get some kind of 3/8" 10mm ball that will Screw into the door???
No, the Strut has not simply unscrewed. No, the Ball has not simply popped out of the Strut mount. Thout I'd save some typing time. lol.:h
  • I should also mention that the longer rope for non-awning conditions shares the weld nut with the shorter rope. We simply grab the rope we want to use.
    Since then, I installed another weld nut lower on the door jamb opposite the door opening, to hang the bungie cords I use to hold the door open. This way everything is stored right where it is needed.
    One last point here. The longer rope does double duty as a quick dry cloths line inside the rig. If we have wet beach towels, a wet jacket, an item needing drying before stowing away, one of us will grab the longer rope and hang it on a cabinet knob on the other side of the entry door. Yes the hanging item(s) is sometime in our way entering and exiting, but it's very temporary. It is better to have it inconvenient, than not at all. Again it is quick to hook, and when done, unhook & let go, and it drops back hanging next to the door, so simple to use and put away.
  • That's a good idea Ron. On my 2017 Jayco Greyhawk, I removed the strut completely. What was happening was the bottom of the door would rub the strut and unscrew it from it's mounting points. So I re-attached it with some medium blue Loctite on the threads, but it was still a hassle so I removed it. I don't like how it fights your arm when you go to close it anyway. Much happier without it.
  • This is not addressing the original poster's specific issue with his door strut being torn away, but seems a good place to share my no-strut solution.
    We bought our rig new in 2007. Back then Phoenix USA did not provide a door strut or other type of door limiter. I wanted to limit the swing of our door in "soft stop" fashion for a few different reasons.
    1) When the awning is setup, the door hits the support beam.
    2) During exceptionally windy conditions, the door would rip out from my wife's hands, swing 180 degrees, and slam hard into the door stop.
    My Micky Mouse solution installed back then continues to work well for us. The rope limiter offers a very nice soft stop. It attaches easily, and in our case, can be attached or detached with the door open or closed. Also, it never is in our way when passing through the door way. We always make sure it is attached on a windy day. Admittedly, it does not work perfectly with the roll-up screen door. Sometimes the screen door will roll-up open when the wind plays with the door held open with a bungee-cord.
    The hardware I used is called a "weld nut". Google pics of weld nuts to see various types. I happened to find nice user-friendly thick round smooth ones at home.
    As the years have gone by, I added a second rope, a bit longer for non-awning conditions. When we want to keep the door open, I bunge-cord the door open, utilizing the rear view mirror. It's hoaky, but it works. I have thought of installing a conventional door strut limiter, but we got well used to this method and it's flexibility to fully open the door 180 degrees....exceptionally nice when the rig is parked at home in our garage.
  • My favorite one..
    https://www.ebay.com/itm/Stainless-Nitro-Gas-Strut-Shock-Spring-Wall-Side-Bracket-Mount-10mm-Ball-Stud-SS/390869500839?epid=24023173265&hash=item5b01a343a7:g:8pkAAOSwBvNTpadm
  • You can buy replacement ball mounts at any Camping World. I saved mine as they break and got a friend to weld the balls back on for me. Bad design, wind will always exceed the ability of the ball to arrest door motion, riveted or welded. I carry spares now. Also search eBay for "gas strut ball stud".
  • Do you have a pic of what is left? If there is enough material leftover, maybe a helicoil would work. If not, something like a "Nut-sert" might work better.
    Yes, this is a common problem, and this is why many towables went away from struts and started installing friction hinges. But the struts are necessary still when the door needs to be restrained from opening 180 degrees.
