ScottG wrote:
Personally, I would not want an EPDM roof that was coated with anything. It's not part of any normal maint. and makes it look like leaks were covered up.
IMHO, it just looks like an amateurish way of taking care of roof issues.
ScottG look around at all your vents, something is coated around them to make a weather tight seal. Where I think people get into trouble is when they use something other than a EPDM product, like the old "snow white" roof coating or believe it or not some people using O'Henrys roof mastic(black tar mix stuff). How else could you get the roof water tight other than a EPDM rubber roof coating at least around the trim (vents, skylight, roof edges, etc) I've had to many branches and pine cones land on roof to not give mine a coat every 4 or 5 years, just to make sure it is water tight. I do also wish the RV roofs were thicker then what I have. I think all of my RV's are 45 or 60 mil thickness right from factory. That is not very thick. When I thought about replacing roof I was going to with 90 mil. But tried (see above post) and I'm real happy. But I can see your point with some folks layering on the roof whatever material they can get their hands on.
