โDec-27-2013 11:13 AM
โApr-10-2014 02:35 PM
Electrix wrote:
You should always manually select the gear when going down a hill, don't just leave the selector in D. The transmission is likely to upshift, instead of downshifting to keep the engine revs high for maximum exhaust brake retardation.
โApr-10-2014 04:02 AM
โApr-09-2014 11:05 AM
โApr-09-2014 10:23 AM
Electrix wrote:
Did they give you any advice on using the exhaust brake?
There has been a bit of misinformation given here.
โApr-09-2014 10:18 AM
Executive wrote:
(snip)...Also, usually it will not engage if the cruise control is ON.....
....Dennis
โApr-09-2014 10:16 AM
โApr-09-2014 01:33 AM
โApr-09-2014 12:06 AM
โDec-29-2013 10:01 AM
BarbaraOK wrote:
Most pacbrakes do not engage until you are down around 40 mph and the transmission in 4th gear - at least that is for us. Start going down by slowing down to 40 or less (depending upon how step the down side is - - use the signs as an indication of how slow you need to be) and engage the brake and take your foot of the brake and let her walk down.
Barb
โDec-29-2013 07:17 AM
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) ๐โDec-28-2013 09:08 AM
calewjohnson wrote:
Do these brakes need to be turned off when entering towns that have restrictions stating such, or is that for semi trucks? I have seen that in towns through Nevada and CA.
Cale
โDec-28-2013 07:59 AM
Cale
โDec-28-2013 07:40 AM
โDec-28-2013 06:49 AM
