- SFVdaveExplorerScrap that idea, thanks!
Read can’t store in outside bay because of lack of ventilation, is that true? I see it done all the time. Could cut vent holes I guess, but it’s a heated compartment. - DrewEExplorer IIRegulations prohibit carrying propane tanks (I'm not sure about cylinders) on a vehicle where they are basically beyond the frame structure--behind the bumper, under the lower frame member, on the roof, or on the front of the vehicle. NFPA regulations prohibit mounting cylinders on RVs on the exterior rear wall or rear bumper, though it's arguable that that probably only applies to manufacturers.
At any rate, it really doesn't seem like a wise idea to me to carry tanks on a hitch mounted cargo carrier, legal or not. I would find some other, more protected way to carry them. - SidecarFlipExplorer IIIBungee cords or rubber bands or tarp straps are fine for securing tarps but not fine for securing stuff like propane bottles. If LE saw that, you'd get a ticket for an improperly secured load.
Do it right, chain it down or use nylon ratchet straps. - MerrykaliaExplorerI know of no law that states that you can't, but...
Several years ago, we were heading down I-10 toward Mobile, AL pulling our TT behind us and a truck pulls up beside of us and motions us to stop. They go on and another vehicle comes up and does the same. We figured we had a problem and DH pulls over and goes to the rear. Our propane tank had come loose when the bungee cord holding it broke and it was dangling behind the camper, bouncing on the road. It was behind held onto the rack by a piece of hose that was entangled in the top of the tank. DH cut the hose loose and slung the tank as far as he could away from the road. It never did explode or anything, but it scared us and I'm sure everyone behind us. - SFVdaveExplorer
bgum wrote:
Just don't get rear ended.
Thought about that! - ScottGNomadPlease don't put it on the back.
- bgumExplorerJust don't get rear ended.
- Old-BiscuitExplorer IIIYES.......
Haul it in the Vertical position NOT laying down
About Motorhome Group
38,707 PostsLatest Activity: Feb 13, 2025
