stugpanzer wrote:
We arrived at a site that is not very level. I pulled in front first as we are overlooking a lake. I do have some plastic leveling ramps which has three levels to drive on which brings the coach up about 6 inches. I then chocked the rear wheels and used the levelers to bring the front end up without allowing the wheels to raise up. Bottom line is we were still rear end higher than the front end. I almost feel like the front needs to come up at least another 6 inches. What do you guys do in a situation like this?
Stugpanzer,
It is for that EXACT situation that I carry a small lumber yard with us. It always cracks me up when you're in a situation like you are and folks suggest, "just move to another spot"! Yeah sure you're going to. Just try that in the Sierra/Nevada/California mountains in any of the campsites there. There's quite a few campgrounds in that region and, during the summer, just about every site, in every campground is "BOOKED UP". So, if you happen to book one without knowing its terrain, and, you arrive and it's seriously un-level, like we did, you have to resort to Plan A.
And that is, start some excavation for tire relief on the high side/end and, building of ramps/blocks etc. on the low end. You don't just "move to another spot" when there isn't any. You have to work with what you have. Storage for a few lumber blocks and ramps etc. can be a problem for many folk out there. I've made it a point to have that equipment as a top priority. This way, you've prepared yourself for just about any given situation/spot.
I'm also one of those that does NOT like to "hang" the front wheels. It's a preference thing. I like as much contact with the ground, with all points as possible for maximum stabilization. To me, if you've got 6 tires, and all are touching the ground or, at least sitting on ramps or blocks etc., and, your jacks/levelers are also being utilized almost to the max, then at least you're as stable as you can be, even with the coach sitting in the upper atmosphere, if you know what I mean.
Now, just what to use for blocks, well that's just a matter of choice. I personally keep (4) 4"x10"x 22" blocks, with one end beveled to be used as a ramp and tire lift. Then, I also have (4) blocks made of two, 4"x6" x 11" sitting side by side and, sandwiched between two, 3/4" pieces of ACX plywood. All is screwed and glued together. Those are primarily for the jacks, if needed.
So, while most guys don't have a problem lifting the front wheels, I'd rather take the extra time and use my blocks so that things are as stable as I can get it to be. My choice.
Scott
