nickmaeExplorerApr 05, 2014f-53 fuel pump pressureDoes anyone know what the correct fuel pressure should be for a 96 class A efi 8 cyl.engine? I'm only getting 20 lbs max. Looks like I need a new fuel pump. Thanks
sailor_louExplorerApr 05, 2014You can find the fuel pressure for most engines here:http://www.jameshalderman.com/links/book_adv_eng_perf_5/s_and_c/Fuel_Pressure_Specifications.pdfAlso, a bad regulator could result in low pressure too so don't just replace the pump until you are sure that's the problem. Good luck.Lou05 Travel Supreme Envoy
Related Content2008 F-53 ChassisF-53 Axle vent26K GVWR F-53 Shortest MotorhomeSway Bar Upgrade Question on F-53Aftermarket Cruise Control 02 Bounder Ford F-53
