spotrot's avatar
spotrot
F53 AC high side pressure (2008 - 134a) at 90F
Can't find it in any of my manuals.
websites suggest 250 psi but wondered if that's correct.
Other sites say 134a is very sensitive to the right pressure.
  • Normal low side pressure is 40-45 the night side will very based on temp how clean the child is etc. if you are charging it do it based on suction pressure.
  • You never charge a system based on low side. IF you charge you watch the hi side with the lo side as a help. Doug
    A/C System Operating Pressures for 134a systems
    Ambient Air Temp (F) Entering Condenser Suction Pressure (PSIG) @ Evaporator Outlet Discharge Pressure (PSIG) @ Compressor Outlet
    50-----5-15--- 75-125
    60---- 5-15--- 100-150
    70---- 10-20---125-175
    80---- 10-20-- 150-225
    90---- 15-25-- 175-250
    100--- 15-25---200-275
    110--- 15-30-- 225-325
  • Thanks,
    Most website charts show 45-55 low side, and mine is at 50.
    The high goes from 275 at idle to 320 when held at about 2000 rpm for a while.
    An old (R-12 era) GM manual says to take the readings at 2000 rpm but I haven't seen that elsewhere.
  • I hope you're talking about the condenser. That's in front of the radiator and looks pretty clean.
    I hope it's not the evaporator. I pulled the drain hose off and over a cup of water came out.
    Does anyone know what is used to seal the drain hole ?
  • Even if it looks clean it may not be. Can you see all the way through it? If the evap has a filter hopefully it is fairly clean but should still be acid washed just in case. I would take a hose and clean the condenser.
  • spotrot wrote:
    Thanks,
    My Chart is from the largest supplier of Dash AC systems for RV's--Evans Tempcon. Doug
