F53 Chassis Lean
TWZMYJP
Our 2018 Jayco Alante has got a leaning problem to the curb side... When it's on perfectly level ground, there is a noticeable list and we often have issues with the automatic steps jamming into the ground when we park anywhere on uneven terrain. Taking it back to the dealer has proven pointless, as they can't seem to find any sort of manufacturer reference or tolerance for allowable lean, and hang their hat on the fact that it drives down the road just fine and isn't wearing the tires unevenly. Has anyone dealt with a lean issue? And no, it's not just overly loaded on the curb side, it's done this since new last season whether we are loaded or not, and individual corner weights are within a couple hundred pounds so that's not it.
'18 Jayco Alante 31R
24 REPLIES 24
crawford
I went through this with Ford before they told me the coach builder did it not them. Went they got the chassis they knew what specs were if they went out side of them they needed to correct the problem.
Change from a c class to a A class Georgetown 07 triple slide
dodge_guy
crawford wrote:
ford didn't built the coach just chassis
Right! But if all the weights are in check then the problem lies in the chassis.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Chum_lee
A full frontal photo would be helpful, or, can you measure the side to side list, in inches, while on level ground from the underside of the front bumper. (to the ground)
IMO, on level ground, the stair when extended, should not be close to hitting the ground, so, something is "off" a little. If this condition existed when new, waiting this long to complain is not helping your warranty case, if applicable.
Chum lee
crawford
dodge_guy
I’ve seen some RV’s where they put spacers under the springs on the low side to make it ride level. But you say the corner weights are within a couple hundred pounds. So it sounds to me like something is wrong with the suspension. Maybe it got mismatched springs at Ford when it was built?
Wife Kim
Son Brandon 17yrs
Dog Bailey
crawford
What DFord saying why not can't hurt a thing ?
DFord
Have you tried calling the Ford Motorhome Assistance Center? The number should be in your chassis owner's manual - not sure if that would be covered under your 3 year warranty or not but they can refer you (and even make an appointment) at a dealer willing to take a look at your problem.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
way2roll
Navigator II
Navigator II
My guess would be the way it's built. Not sure what your floorplan is but it's probably very heavy on that side. Was it something you noticed on the test drive? We had a MH once with a full wall slide and the refer etc was in it and it would list ever so slightly to that side. Made sense as all the weight was on that side.
Jeff - 2023 FR Sunseeker 2400B MBS
MountainAir05
as state springs, or way to much weight on that side. You are measuring the frame not the body the builder put on.
crawford
I would start checking all your springs and hardware something is off for sure. Check at you leaf springs maybe a broken leaf or 2 could cause it also.
