2wheels's avatar
2wheels
faucets
Need to replace bathroom faucet in 2004 Seabreeze lx.
Can't find replacement faucet.
  • wa8yxm's avatar
    wa8yxm
    I found suitable replacements everywhere when I replaced one of mine.
    Now I wound up buying at an RV dealer because of two things
    They had the type I wanted (not a typical bathroom faucet but a "Bar" type with a high "neck" that had the room to clear my water jug in case I wished to fill it on the attached filter.. I now do the jug differently so ...) and
    2: Beleive it or not.. CHEAPER
    For the kitchen I went to eitehr Lowe's or home Depot
    But both are standard faucets any hardware, pluming. RV dealer or big box home improvement store.
    One word of caution. For the bathroom you are likely going to have standared 1/2 inch IPT threaded connectiors.
    For the kitchen they may be standard...or not.. I had to make a few connector changes. Not a problem.
  • Insead of replacing the nuts in the faucet hold downs with just plane hex nuts, use stainless steel wing nuts with washers. much easier replace, and removal if necessary no special tool will be needed.
  • ^^^ These. Normally there's nothing special about an RV faucet. I've changed a few myself over the years.
  • Just measure the distance between the holes any big box home supply carry them.
  • Purchased mine at Lowes, same as a house faucet. I got one that the neck swivels side to side, kind of convenient with a smaller sink.
    Blessings Keith
