KAYPAY wrote:
Greeting, We are looking to move from our class B to a Fleetwood Storm. We reallly like the floor plan of the Storm 32V , presently looking at a 2016 model. Does anyone on this forum have one or know anything about the quality of Fleetwood in the past few years.
IMO, quality, like beauty, is in the eye of the beholder. I own a '99 Fleetwood Storm 30H. At 21 years of age, I can tell you that everything eventually wears out and needs replacement and/or attention of some kind. Some items sooner than others. Looking at the newer models, Fleetwood appears to have changed (upgraded) some surface finishes, but, the Storm line still uses economy grade cabinets, fixtures, floor coverings, etc. that all eventually wear out with use. As that happens, be prepared to repair/replace them with upgraded amenities. (if you prefer) I don't know if Fleetwood still offers a choice of Workhorse or Ford chassis. The two chassis vary in their specifications, specifically, gross weight and towing capacity. While you have a choice, make sure you consider the most appropriate chassis for your specific intended use.
As others have mentioned, generally your current Class B will have a higher grade of fit and finish than most Class A gassers, but, they can't compete with the GVWR, storage, and towing capacity of a Class A MH if that is important to you.
Chum lee
