alextwister1 wrote:
I have a 2008 Fleetwood Fiesta on Ford F53 chassis with 19.5 wheels and 245/70/19.5 tires. I am looking for a spare wheel but I am not sure if the wheel width is 6 inch or 6.75 .
This the correct wheel you need..
https://www.finditparts.com/products/8283694/accuride-29879pkblkI ordered 7 black powered coated ones from this place, I had a couple of old rims that were bad so I replaced all 6 and the spare to black, I have a 2008 Bounder on a Ford f-53 chassis and they were a perfect fit..
Your size is same as mine
19.50 X 6.75 rim
10 Hole on 225mm Bolt Circle, 170.10mm bore
245/70/19.5 tires
Do Not get the 6 inch wide rim, the 245/70/19.5 tires wont fit..
The link above is the exact rim you need however its the black one, you can contact them and order the white or gray one to match your other rims..
