MrWizard's avatar
MrWizard
Moderator
Jun 16, 2022
Ford 460 engine accessory V belts
Multi V 6 rib drive belts
There are two
The outer belt drives the Alternator and air pump
The inner belt drives the power steering and the A/C compressor,
The outer belt continental 4060505, was easy to find and a perfect
The inner belt was much harder as all the so called matching replacements were too long, after 3 trips too parts stores and several phone calls, the local Napa store found a belt listing in his book with correct lenght specs,but mot in stock at my store, went 8 miles to the next Napa store to pick it up
Napa pt# 060594, a perfect fit replacement for the inner belt
Little more than an hour to install the new belts (i had assistance) but spent several hours tracking down the inner belt,
That is how i spent Wednesday
Not a fun day, not the worst day, but certainly tedious and frustrating ,
These events began Tuesday evening with the discovery ofno output from alternator,
Reason was no Alternator belt it was gone
  • Thank you for this information. We are broke down at a KOA and my husband has been back and forth to auto store 5xs. I wrote down the inner belt pt number and he went back and they found one that works. Thank you, thank you!
  • MrWizard wrote:
    Yep, Great engine, just hard to find that particular belt, i guess Ford did not use it with any other engine & chassis configuration,
    Well yes, Ford did use that belt configuration on 460 F350s. The radiator hoses only Fit F53s.
    Richard
  • Yep, Great engine, just hard to find that particular belt, i guess Ford did not use it with any other engine & chassis configuration,
  • One of the great things about the old 460 is that we don't need the alternator belt to get down the road. Both belts wrap around the water pump. My alternator belt failed one morning and I made it to my destination by running the generator to keep the house battery up. Found a parts house and made the repair that evening.
    Richard
  • Carrying spares is a good idea, i have a load of fuses, bulbs, wiring, rv water pump, hose, fuel line, battery cable terminals , etc..
    For me, my mind set is that having the tools & knowledge is more important than carrying all the possible break down replacement parts
  • time2roll wrote:
    Belts last far longer today. The replacements will probably out live most of us.
    This is true, but the habit of packing a spare dies hard. Normally I put the take-off in the sleeve new came in. This will get me home, and give me part number.
  • Belts last far longer today. The replacements will probably out live most of us.
  • Are you planning to keep the vehicle? Might be a good idea to track down replacements now, carry with. If you have belts you are unlikely to have trouble, but if you don't you could be setting for days.
