DaHose's avatar
DaHose
Ford 460 power increase - california smog legal
Hey, people. As of late, I have been dealing with engine performance issues in my 1983 Jamboree. Good old Mabel is running a California spec. Ford 460. I live in Ca. so I spoke with a local star certified SMOG shop about increasing power output and got some great news that I think is worth sharing.
While California SMOG requirements really limit your ability to increase engine performance, my old girl does NOT have catalytic converters and the air injection is not in the manifolds. The air is injected through the head, directly into the exhaust port. That means two GREAT things!
1.) I can add any kind of headers and be smog legal, so I ordered a set of Hedman headers and will be wrapping them with a blanket. That will reduce radiant heat.
2.) If I really want to improve performance, I can remove the heads and have the exhausts ported. The stock heads gain something like a 20% increase in exhaust flow when you port them.
I can do both of the above, pass smog with no problem and definitely will see gains in engine performance and reductions in heat transfer to the cabin.
A well know upgrade for a 460 is installing a 0 degree cam gear setup. However, I need to find out if modern fuels would allow me to still pass the sniffer test with the 0 gears installed. If I could do all three things above, I might pick up more than 100 HP. It's too bad I can't change the carb. too.
At any rate, I will update this thread as things move forward.
Jose
