Harvard
Sep 03, 2015Explorer
biggic, at least have your alignment checked and if the caster is not more then +5 degrees then it is probably an issue. Better still post a picture of the top of an upper ball joint and we can pretty much tell if you have factory caster settings which are fixed at about 3.5 to 4 degrees.
Here is an example picture of factory default fixed settings.
![](http://i.imgur.com/fPadITUl.jpg)
38,707 PostsLatest Activity: Feb 17, 2025
