tatest wrote:
Even if you do not have the upfitter switches installed, one of the electrical boxes (under bonnet) has sockets for the relays that would be controlled by those switches, which would let you install a relatively high current circuit that could be switched by one of the "hot when ignition is on" circuits.
I don't know the needs of your camera, whether the current demands are low enough to share a circuit with the switched line to the radio.
A dashcam is not a high power device by any stretch. It likely uses less power than a cell phone charger (while charging the phone) or an automotive GPS.
