โMay-01-2017 06:32 AM
โMay-04-2017 06:11 AM
โMay-04-2017 05:07 AM
j-d wrote:
Might rain, so I got the cardboard out, slid under with a handful of sockets, and here are the E450 sizes, through Chassis Year 2007:
Front and Rear Sway Bar Center Bushing Brackets: Metric 15MM
All parts furnished by Hellwig: SAE 3/4"
There isn't an SAE size that'll "work as 15MM" so you need that specific socket. Standard depth is fine.
You can get away with 19MM for the 3/4" but the socket should be Deep.
I always get Six Point Sockets.
So you'd need a Ratchet, two Sockets, and a Wrench.
Wrench can be an Open End, Combination (box/socket end plus an open end) or an Adjustable. 8" would be nice, but a 6" will open to 3/4".
Again, suggest 1/2" drive for the sockets. I don't like the fastener diameter much bigger than the square drive size of the socket set. The 3/4" tools will be working 1/2" fasteners, and the 15MM is driving screws that are about 7/16".
Footnote: 2008 and newer use two different sizes on the front bar center brackets, the 15MM and something larger. Common next larger'd be 17MM but I don't have a vehicle to check that on.
EDIT: Looked at the OEM rear sway bar end links I removed to install the Hellwig bar. The 3/4" or 19MM socket will remove the frame end. The bar end is 14MM but your 15MM socket'll catch it if you get a six point. Or if your open end wrench is an adjustable.
โMay-04-2017 01:56 AM
โMay-03-2017 07:19 PM
chag67 wrote:stripit wrote:
The factory bars are removed and the new heavier built, thicker bars are installed.
How difficult/easy is the install? Does anyone have a link for step by step instructions or a video?
โMay-03-2017 01:27 PM
โMay-02-2017 11:37 AM
chag67 wrote:
I'm positive I need them. I felt the rig move at every movement of my son in the overhead bunk. I also felt the rig move at every wind gust while parked.
Plus, traveling home, my hands were cramped and sore from having to grip the steering wheel so tight.
I don't mind paying for the Hellwig sway bars but I don't want to pay for installation if I don't have to.
โMay-02-2017 10:55 AM
โMay-02-2017 10:24 AM
โMay-02-2017 09:57 AM
โMay-02-2017 07:46 AM
โMay-02-2017 07:18 AM
chag67 wrote:
I noticed a lot of sway this past weekend driving my 2007 E450. Does the hellwig replace what is on the rig currently or is it in addition too? Please excuse my ignorance on the subject since I am not mechanically inclined at all.
โMay-02-2017 06:35 AM
โMay-02-2017 02:21 AM
sullivanclan wrote:
What would the hellwig rear sway bar cost?
โMay-01-2017 11:18 PM
