piconroy
Jan 08, 2017Explorer
Ford E450 vs E350 under a Class C
This also appears under a different post as well re: stretching Chassis. I'm looking for some more opinions / tech intelligence. We looked at a 31' Class C but rule it out in part because of some of what I have learned in these forums. Other considerations were it's very difficult to store at home & wife would not drive it. Also determined that for the type of travel we intend something shorter would be better. Saw a nice Itasca Spirit R22 but just too short. Now I'm going to look at a Winnie 25B. On paper looks nice. Priced right but now the confusion. I'm convinced, sure some of you are too, that the RV industry wants to keep us confused so we just throw in the towel and buy. Anyway, I have read some opinions that it is better to have the E450 under you then the E350. Reasons, such as the V10 won't work as hard as the E350 etc. There has to be obvious differences between the 2 chassis and I would like to know the trade offs. Normally the 350 comes with the 5.4L 8cyl and the 450 with with the 6.8L 10cyl. BUT this 25B is on a 350 chassis but comes with the 6.8L 10cyl and the same transmission as on both chassis. As it is still on the 350 the GVWR still remains 11,500lbs. So, I read that the some of the chassis differences are 450 has much (larger) more breaking capacity and a much HD rear axle & I assume at least a slightly bigger GVWR #. Okay good but is that all? is that enough of a reason to avoid the 350 chassis even with the V10? I would think the v10 answers the power issue but but am I still setting myself up for other performance disappointment on the 25B if it's on the 350 chassis. Thanks,PAT
